Up date: Old post, Oct 21, 2021. I’m older, boat is older and boat has just been sitting, except for me or others turning prop many rotations fairly regular and cranking with battery regularly at beginning and less now as health spiraled. Never got boat running properly, haven’t used it, engine may be beyond repair (still have extra engine in barn in dry climate), looking forward to working on it, and again hoping for and looking forward to help and advice.
Reason for departure, polycystic kidney deasease. I spiraled down. I’ll skip all the drama and get to the results.
Two alien eggs were removed from me (both kidneys) and on hemo dialysis to keep alive till a new/used kidney installed 2 1/2 weeks ago. (Normal kidneys are the size of your fist, these were the size of footballs and growing, thus the removal of both.
I’M BACK!
Hopefully I/we can perform another miracle, and revive the boat. Getting stronger every day, and look forward to learning more about aircraft engines. Thanks for all the previous help, and sorry for just fading away.
At this point how should I start. My thought are: marvel mystery oil in all plug holes. Let sit for a few days with plugs in. Remove plugs and wiggle back and forth moving more each time by hand. Then change oil and filter, get new battery, see if it will crank, (not likely), repair or replace what needs replacing (switches, wires, whatever) get it to crank. Replace fuel. Can I use starting fluid to confirm ignition? Replace fuel etc… Also keep fingers crossed.
