the mini is getting there
Lookin good but you may need more prop :D
i got a kick out of this is that a vw with the trans/ also on that prop this is where i got the kick you guys sey more prop heck im lookin at the pitch it looks a lil flat
wow thats a wierd lookin car but hey make it work but am i right it has the trans on it?? also just my opinion you might wanna put a x brace on that stand front n back you may not need it but i always ran them i built engine stands at alumitech for a lil while but im not familiar with low hp motor so just thought id let ya know
:D yes you are right there is a transmission box on there modifide the box added some berings modified pto or main shaft which is the original , used avation aluminum plates pullies ratio is 2.25 to1 this motor runs perfectly 6000 rpm the idea is to runn at 4000 rpm get a 3 blade 59¨ ultra prop with 13 digre pitch should hit 2400 i hope hahahah good idea on rienforcing will to that Thanks :) :) hay bro this is my first boat so any adds are alwase well rieceved :D by the way my hull is 3,90 long by 1.60 wide so far wight is 127 kg hope she flys on de water :shock:
Hay Josh
look me up in the Pictures and photos under my Nic when are you going to post a few photos i have been reading your messages but havent found a photo :)
