Hydroflight
Active member
I am starting to build my second airboat after 28 years. I am a little more than out of touch with the mainstream of airboating, being in the Portland, Oregon area. I was hoping you fine gentlemen could help me determine the perfect hull for the new airboat. Here are my plans to date. I plan on powering the boat with a 220 GPU and 72 inch two blade composite prop. My thoughts are to rig the boat for three people with front drivers seat and a double rear seat. The boat will need to be able to run deep water with 3 foot swells and run dry ground. Over time it will hit everything from rocks to tree stumps. It will need to turn very tight to avoid river rock and floating dead heads. I believe if anybody knows of such a hull it will be you guys. I look forward to your expert advice.
