This subject has been covered before by thunder and others ,considering the circumstances I thought it worth mentioning again.Here at work the operators use one of two boats to get back and forth to there machines in the salt marsh.The old diamond back went through a motor after 300 hours the replacement lasted 97 hours and it,s replacement lasted a whopping 37 hours all the engines were 330 hp gm engines purchased from three different air boat manufactures ,the boats were always operated on water never stuck .The final conclusion for the failures are running out of oil at high rpm.It never fails ,tring to save a dime will cost you dollar .The plan now is to outfit the next engine with the proper AIR BOAT oiling system.Do not assume that an air boat manufacture will sell you an engine that will stand up to air-boat use. My opinion used to be that the average air boat car motor would last about 200 hours until I met a gentlemen recently that had maybe 1800 hours an his big block .So I know for a fact engines can be made to last with some minor modifications .Which I'll admit to the fact that my Knowledge is more that a little week on that subject.So what say y'all other than dry sumps what are some good easy solutions to this problem ?
