OK I just put in a set of NEW gauges and first day out the started to get those dam water beads (Contestation) in them. Is there any way to get them out, will they leave or I'm I stuck with them?
Thanks
If your gauges have lights, you can remove the bulbs from the bottom, use a blow dryer and blow warm air up through the holes and then when you replace the bulbs, put a little silicon around the socket. If there is no way water is getting in there, you may need to cover the gauges with plastic. Use only the warm setting and be patient 'cause really high heat isn't good for the gauges.
