throttle cable and assembly for LS
What throttle body are you using? If it’s not drive by wire. Should be able to use a standard auto type cable, as long as it’s long enough. And a standard pedal assembly sold by most airboat companies. I know around here Hamant and diamondback carry pedal assemblies and cable systems that work perfectly.
Thank You! I will give Hammant a call!
I used a pushpull cable with a Custom bracket.
Link below.
https://www.mooreparts.com/throttle-body-cable-end-for-push-pull-shielded-throttle-cables/
