Hey Guys,
I recently replaced my throttle pedal assembly and cable. The old pedal was bent and binding up. The new assembly I put on worked great the first few times we rode then it started binding up not bad it of course only seems to do it when I need the power.
I looked at the linkage and it appears to pull straight to the carb linkage, but when it binds it appears to do it with the pedal linkage like half throttle, any ideas what else to check, my return spring on the carb is a little stiff maybe a lighter return spring?
I need to fix this, I dont want to be on the bottom somewhere in the river !!!!
Thanks
Jim
Thanks
Jim
