Waterthunder, others: No gear drive is now nor has ever been available for the Cadillac. Only the single roller cloyes chain. A friend of mine built one, which was a huge pain since the distributor shaft is in the front and poorly placed to design a gear drive. It was fine, but a one off custom piece. The weakness in a Cadillac is the very small crank sprocket-----if you tap it on with a hammer, it will run from 1 second to 3 hours before it shatters. You must use a concentric ring of some sort and Eeeeaaase the bottom gear onto the crank. Charles
