Andrew1985S
Has a anyone used one of these on the aircraft motor , it's simple to hook up but I am confused about the settings I have a 0320, so a 4cylinder should have 2 sparks per Revolution correct ?
Instructions are straight forward
Ground to engine block
Red wire wraps around your spark plug wire. If I use the other settings I get readings that aren't right at all
So I get left with a 180 option which is the 2 sparks per revolution and that's the one that makes sense to me
