torque on warp drive props
the hub bolts are i think 65 ft lbs and the blades are 210in lbs can't quite rember so i just tighten mine tight on the blades
5/16" clamping bolt 240" lbs
3/8" mounting bolts 40 ft lbs
1/2" mounting bolts 60 ft lbs. These numbers are from
from warp drive manual.
