Priorty1
Everyone has been a big help so far. So let me pose another question.
I was told that all Gear to Gear reduction units change the rotation of the motor from counter clockwise to clockwise, and a Belt Drive reduction unit does not. I was also told that a Gear to Gear set up would be more likely to cause torque roll. Here's the question: a motor turns counter clockwise a belt reduction unit turns counter clockwise thus the prop will also turn counter clockwise wouldn't this set up be more likely to cause torque roll. My thought is with the motor turning counter clockwise and the Gear to Gear changing the direction of the prop to clockwise that the two would cancel each other out or close to it.
Thanks all
Thanks all
