I like the lenco small tabs.
I like to cut the trim plate from the hinge, and remove a 1.5 to 2" strip of length from the hinge area, then re-weld it to the hinge.
If I remember correctly, we wind up with about six inches from the hinge, to the actuator mount on the plate.
This increases the overall throw available by a huge amount.
This way I can have plenty of travel for a super high up position, and still have way more than enough down travel for trimming if needed.
This length from the factory just does not afford enough thow for a proper airboat application. It's plenty for a regular kicker boat, and that's what they designed them for.
This does effectively lower the mechanical advantage for the actuator, but they are designed for large boats, and are way overpowered for what an airboat requires anyway.
As Whitebear stated, caution should be used when trimming your airboat with a powered tab. Too much tab at high speeds could cause for a lot tighter turning, than will allow you to stay in your seat. Just give it enough down to stop the bounce, then back it off a bump. Then bump it back if needed.
Then of course, you'll have to tell yourself to pick it back up before you hit the dry.
I want my tabs UP when not deployed. WAY UP, if I'm gonna have one.
