CONTINENTAL CRACKER
anyone have a older style powershift 2 blade outer hub?it has the threw bolts.found a small crack in the outer plate on one of the bolt holes. can the be wielded?or will that throw it off balence?
are you sure they are matched ,i am not questioning you; just curious.usually the tips of the blades are weight matched to take care of any out of ballance.in my thinking if they ballanced the hub they would have to balance all together as a set including the blades.inner rotating force is not as badfTony480":31hsxilr said:You can't mismatch hub halves,they are balanced.Call PowerShift they can make you a new one.
bondsman":2k6i0z7u said:hey captain chad,i guess i could have put your screen name together and figuered that out.glad those worked out good for you.lone cabbage is that in around the area or was i way off?
