Bob Burnside
What do more run on their boats? what are the advantage of each. Stock or aftermarket distributors what do you like?
Rutting Moose":2wow02i0 said:Now I'm confuse, what do I do????
I have a Chev Marine small block engine, 1996, vortex 255/294 HP? @ 4400 rpm.
Iron heads and iron block, alum high-rise intake.
I got it from Marine power model B350P, 350 Premium
Marking on engine 10243880, V03117MH, & C0700013
Edelbrock model 1405 600 cfm
This is not a hot rod engine, but a Marine engine like a Kodiak less the water intake. It came with a 3/4 1 inch thick fly wheel.
The book said initial timing 8* @ 500 rpm, total timing 26* @ 4000 rpm.
What do I set the timing to?
Do I remove the vacuum advance?
Tom
