Your prop vibration could be something as simple as harmonics between the engine and the prop, although harmonics are not simple. The short and simple in the aviation world the prop and engine have to be certified to work as a unit, and on the 4 cyl. lyc. you have a prohibited area in RPM that you can not run for long periods of time, due to harmonics, I'm not saying that's your problem ,I'm saying that's possible. I run a 6 blade 80" turbo Warp and I have a vibration in a certain RPM range of about 300 RPM and I set my blade angle with a digital protractor. I hope this info may be of some help, ZZ.
