Florida Air Prop told us when we bought our new prop from them that even if stored dry the INTERNAL moisture can seep to one end of the prop if stored up/down. Even if stored indoors i.e. if it's off the boat, store it FLAT, not leaning against the wall.
So there is this rule: store your boat with the prop sideways/horizontal. Tow it with it up/down for less wind resistance. But remember to give it a 1/4 turn when you get home. A day or two vertical is not a problem - just not weeks stored that way.
I don't know if putting the heavy end up for a few days/weeks would fix it. You may have to take it back to the mfgr to have it refurbished and re-balanced. I think they strip it to bare wood, let it stabilize to uniform internal moisture for a week or two, (maybe they bake it in a kiln) then put on new metal leading edges & tips, re-balance and re-varnish/paint it. I think it costs 2 or 3 hundred to have that done.
Don't run with an unbalanced prop! Check your welds for cracks & chipped paint at joints.
matt.
