I never could really get anyone at powershift, sensenich, or warp drive to give me the real answer for what if the perfect pitch and RPMs for a blade. Or at least an answer for that question that matched the answer from another company.
I think power shift used to say with each style of propeller what the maximum RPMs for that blade was, and each style was quite a bit different. We switched from one of powershift's early 2 blade props for an 0-540 that was a cut down version for the 350's. Now they run another style, I believe a signature or cypress style, and both have different suggested maximum RPMs. And the newer Maximus (spelling?) blade for 502 and 454 sized engines turns way less than 2600, in fact I think Max RPMs is around 2400.
The older motorheads around here used to dyno their motors for HP and torque. They always were looking to get a prop to turn just slightly more than the peak of the torque curve on the engine or just below Maximum RPMs, depending on the what motor it was.
Running those 0-540s we always tried to set the pitch on the composites so you could turn up right at 2750 tied onto the trailer. In the field that might be 2800 + or - 50 RPMs. This was just due to the cost of a crank, cam, or block. Lycoming suggests this as the maximum limit for 0-540s and you never know what crank is in the block with some of these motors. However that early Power shift we had would turn 2930 on the old angle valve it was mounted to if you stood on it in the water.
