would work better if it was more reduction, but just pitch the blades less and it will work pretty darn good.
You're probably looking at a starting point of around 4.5 degrees at the blade tips if you want some throttle response
I'd look to turn the prop to around 2500 RPM, which would put you at 4425 on the engine.
I don't know how heavy your boat is, but that should make a decent ride boat and climb the hill a little bit
