Basin_Runner355
Looks like the ls2 has a lot less timing I guess that’s Because a factory ls1 and ls2 the ls2 has smaller combustion chamber which bumps up compression and therefor less timing to prevent detonation ?
What heads?
It has trick flow heads.
Why don't you use the formula ...it has nothing to do with" what you think"
Because the formula don’t add up. Gm puts a 750 cfm on the zz4 motors why would more motor need less carb
With a carb you don't need a MAP sensor. Carbs are dumb. Vacuum draws fuel. MAP sensors are for fuel injection. MSD box only drives the coils by interpreting the cam position and crank position with the exception of the temp sensor which tells the box when the engine is warm enough to give it full timing. The box does have a hose port to hook up to the manifold for supercharged or turbo applications to pull timing as the MSD sees boost pressures. The LS platform is far superior to the old small block in many ways. At 540 hp just run that bitch, trying to get every ounce out of the engine shortens the life and causes potential problems. I'm gonna back the timing down on our LS2 I just built, old man don't need 511 hp on a 13 foot Hamant, I'm looking for longevity.And I see why nobody In Louisiana switched over to the ls motors they a pain in the ass . I can’t wrap my head around how this msd ignition box works because there is no map sensor to read the pressure.
(Almost) Everybody in Louisiana (and Florida etc.) has already switched over to LS in their trucks, they started making then in the 90's. The only reason no one is familiar with them is because their trucks ain't broke.And I see why nobody In Louisiana switched over to the ls motors they a pain in the ass .
This I don't understand.I can’t wrap my head around how this msd ignition box works because there is no map sensor to read the pressure.
I don’t understand it either. That’s why I’m asking. The only two sensors it has is the one that plugs on up where a distributor would be on a sbc and behind the starter.(Almost) Everybody in Louisiana (and Florida etc.) has already switched over to LS in their trucks, they started making then in the 90's. The only reason no one is familiar with them is because their trucks ain't broke.
Yep, it's different, but in a good way.
The MSD 6014 LS Ignition controller works with 24x/1x and 58x/4x crank/cam configurations. It auto-detects the correct configuration based on the reluctor wheel pattern, so there is no need to select one. It provides six pre-programmed (non-editable) timing tables for stock engines, three customizable 3-D tables, and one customizable timing plot. The desired table/plot is selected on the fly using the rotary dial. The customizable tables and plots can be programmed via MSDView. The LS Ignition controller includes a built-in 2.5 Bar MAP sensor that can be used with Naturally Aspirated or boosted applications. This allows for timing advance or retard based on the intake manifold pressure. 8MB of internal data logging is also included so you can set up, record, and review passes at the track. As the popularity of GM LS engines continues to grow, so does the demand for a powerful, reliable, and easily adaptable ignition system. MSD has answered this demand with an updated and improved version of the popular 6LS box. Whether using a stock crate engine or building a custom powerhouse, the MSD LS Ignition provides the control you need to achieve the performance you want. Dial in the perfect tune for your LS using the easily adjustable preset timing curves or hook up to your computer and program a custom setup with our user-friendly MSD View software. New features of the LS Ignition include; high-speed data acquisition, an optional coolant temperature sensor input, idle timing control, as well as individual cylinder timing. These features are in addition to the existing programmable step retard, launch retard, and RPM rev limiters from its predecessor.
Features:
- Fits most LS Engines
- No PC required for basic functionality
- Six preprogrammed timing tables for easy set-up
- Rotary selector switch allows timing changes on the fly
- Nitrous and boost compatible
- High speed data acquisition
- Fully Sealed direct plugin connectors
- Programmable step retard
- Launch and max rev limiters
- Optional coolant temperature sensor input
- Launch retard
- Idle timing control
- Individual cylinder timing
- Compatible with all MSD, Accel and GM LS coils
Ida liked fuel injected i bought the motor it was already built and ready to go with a carb.All the money in a carb intake, new carb, med management system, and you could’ve had a fuel infected boat that you don’t have to rejet in the winter. I stepped outta my comfort zone and went injected on my new boat and I will tell you this only maintenance between seasons so far is just verify oil level and hit the key love it
No offense to anyone one but if you having a hard time understanding this carb/MSD setup then fuel injection is not for you, it doesn't get much simpler. Just sayin! I'd just assume running injection but the boat came with a carb so that's what we're using. OEMs didn't ditch the carb just for giggles, injection is more accurate (again properly tuned) and self adjusting. I run a self learning on my Windsor. Dad doesn't really care as long as it starts and goes. He quit wrenching for a living when fuel injection was coming to market, he didn't want to learn the new system. Old dog new tricks deal.All the money in a carb intake, new carb, med management system, and you could’ve had a fuel infected boat that you don’t have to rejet in the winter. I stepped outta my comfort zone and went injected on my new boat and I will tell you this only maintenance between seasons so far is just verify oil level and hit the key love it
What intake is on it? Single planes can get away with a smaller carb. The 650 will probably be snappier down low. Manifold velocity is key. A larger carb will make more HP up high, as long as it's not too big. When we dyno any engine we pay a lot of attention too the vacuum readings. It tells us if the carb is too big, too small or just right. 3 bears scenario. LS engines do move a ton of air.
