JAMES":1cl3lfp9 said:WELL ME AND WOODY ARE BUILDING MY CADDIE BOAT FROM THE RIG TO THE MOTOR AND I WAS GOING TO SET IT UP AS D/D I FABED THE CAGE SO IT WILL BE RIGHT FOR A GEAR BOX AND I CAN MOVE MY STAND HOW I NEED TO FOR THE BOX THE PROBLEM IS I SOLD MY OLD D/D CHEVY BOAT AND WANTED MORE POWER BUT DIDENT HAVE THE MONEY AT THE TIME FOR A BOX OR A GREAT PROP IF THIS BOAT PERFROMES WELL IM GOING TO LEAVE IT ALONE I JUST WAS THINKING WHAT IF I WANT A BOX THANKS FOR ALL THE HELP !!!!!!!!!!!!!!!!!!!!!!!
I SOLVED THE PROBLEM ILL FINISH THIS BOAT AND SELL IT FOR A GOOD PRICE AND PUT SOME WITH IT AND BUY A JIMMIE WHITE HULL AND SET IT UP WITH A GOOD CADDIE MOTOR AND A BOX THANKS GUYS
AND I WAS THINKING OF A COUNTER ROTATER ALSO
a1mudpuppy":2mz7fz7h said:Lots of good info here. I was going to put a 1.77 on my caddy the Cntry talk some since into me and I purchase a 2:38. I had a 4 blade 78" stump puller which wasn't enough prop. Now I have a 4 blade Master Blaster 2.3 and I'm @ the 23deg mark turning 4500rpm. It pushes this 4000lbs GTO airboat pretty good. But you must MUST built up your valve train. Potter has some nice stuff to do that with. I punched mine out .60 and put in forged flat top pistons with 120cc heads with the bigger valves. Custom grind cam , Elderbrock intake with a 750cmf.
a1mudpuppy":23cm45en said:OH and a Stinger Box which after the sale service is great!!!!
