If some one doesn't take car of you there give me a call. We are in Marion county. I have run it on HEI Dis. The digital 6 box with retard mod. is a nice way to go. The 7 al3 msd and the hvc11 coil is the sweetest and has all your stages of retard built in. It is safer that way. That way you run normal and when you hit it it takes timing away from it. You will also need to go 1 or 2 stages colder on your plugs. We have a ride boat with a 150 on 93 you could look at or ride on. If you don't like hotroding it is the best unstuck button out there!
