who makes gear boxx for 4.3 chevy
J-bub
W.T. doea someone make one and stock 4.3 what cam and intake and carb would ya prescribe.
small talk last night about firtst boat trying to work with what I got for first boat 12.6x7 glass hull pancake cage 2 single seat. looking for advice from the motor Gods.....
Either the Stinger or Rotator will bolt right onto one! I have built a bunch of them motors for airboats. They are cool little motors and can make some power we were up in the 400HP range with them. Make sure to run a 2.68 ratio and run more came then anybody will tell you to. I learned that from a guy who use to build Grand National V/6's Remember all the pistons and valves and small parts are the same as a SBC!
thank ya, I thought but thats when I usually get in trouble.. 4.3 is a cut off 350 but wasn't sure if gear box would bolt now I know.. Do ya work on boats in cocoa or cars I see you and Felber building big engines.. any way goin to look at 4.3 tomorrow suppose to run and the price is right I just gotta put it ... might wear ya ears out if everything comes together...
I have one complete nasty 4.3 left to put together anything else I have left over you can have! I might have a pic from a few years back a 375HP I built with a gearbox on it! The owner would only run a 2.38 so it only has a two blade power shift on it!
Here is a pic of a Rotator on a 4.3 V/6
p.s. Iate up a few O540's with it and a nasty 180 with N2O too!
Thanks for all the info I believe I can go to bed knowing I might be able to do something with a 4.3 plus I don't mind p^^^#*^g off a few a/c motors if I can get this thing set up right . good night W.T.
Boy do I feel dumb I just happened to look at your web site. I/m 100 % sure it will be car motor/gear box 4.3 just something different
HAVE A GOOD NIGHT.
The 4.3 was a good platform the only reason I stopped using it is because the LS motors came out and they are even lighter! Those V'6's can push a boat real good! I had fun with them. Are you going to go thru the motor or are you putting it on the boat as it is!
W.T. If I can sell or trade my fishin boat and tax time =good glass hull+4.3+gear box=wahooo
probably gonna have to replace at least bottom end like i said I aint no mechanic but seeems to be place to start solid bottom and add along the way. Point blank when I get cash in hand I will come see ya for a mild (budget 4.3 hahahaha they don't go together do they)...
give me around about price for solid motor+gear boxx 2.8 so I know about what to hide from momma.LOL[/b]
I have been toying with the same idea... I picked up a 96 4.3 that needs to be gone threw. However I looked on Jegs site and only seen a very limited amount of aftermarket cams (1 or 2). Where is a good place to get a radical cam from?
Thanks
I aint real sure done the same thing..I guess W.T. would know what parts are available but if the price is right LS motor but I really like the idea of a 4.3.. on 12ft. glass I guess I need to quit wishin until I get my tax return or boat gone
