Who makes mini airboat hulls ?
Well, there you have your answer depending on whether you were after fiberglass or aluminum.
If I recall correctly (and I well may not), the MiniPro molds that Marty was making were 10 1/2' and 11 1/2'. In any case,
the later of the two was nearly a foot wider than the other, and would be my recommendation if you are opting for 'glass.
For what it's worth, those two manufacturers are both well beyond 'decent' hull builders, and debatably represent the better of each type.
I would Highly suggest you take Mike's advice as far as a mini hull and power plant! You seem to be posting all over the place for something ,,,,, and I hope it's not for a 220 build. Not that 220's are anchor's or anything but not such a great idea on a mini.
"Bottoms Up" has a totally new reference to overpowered mini's!
