I am not sure if better is applicable. More like which do you have available and which are you better at ? When using a Mig I found it best to lay it on the pipe first and roll it over the wire so as not to burn the wire in two, its kinda tricky. Brazin is good maybe it is better if done right but the trick is in the doin either way.
