Watterbug
Last test reveled I needed more work...
So I moved the motor( 300 pounds ish) back seven Inches and plan to tip the prop/drive UP 2" from level on the floor.
I'm also moving the fuel tank to about the center of the boat, 15 gal.
I was driving the nose of the bot in to the water the harder I pushed the deeper it would go.
I also did some drive work and changed the reduction to 1.6 to 1 so at 4000rpm on the bug motor the prop will be 2500.
I'm hopping for a little more go.
1600cc 34carb the prop is wood and marked 64x 32.
You think it will be enough?
This time I made it so I can move it back another foot and up what ever I need.
:?: :scratch:
:?: :scratch:
