Cold, I will be glad to, it will take me little time to send you some pictures, but I will not forget. I'll write myself a note. It works quit well I got the idea from stern drive outboards. What I do is make an engine mount that has it's pivot point in front of the engine, (all thought this may not be entirely necessary), it does slow down the rate of pitch angle change when you are changing such angle. I then go to the rear and mount a jacking device. I have used two kinds ele. over hyd. and ele. over mechanical (jack screw), with a safety device to keep the engine travel safe even if the jacking device fails. I’ve thought about of going into some kind of production, but airboats can sometimes be a bit funny about new ideas. It has a greater effect for trimming because you are trimming the thrust angle. I hope this info will help you, where do you boat? ZZ
