If the engine runs that cool, the zz3 should run fine with a relatively agressive timing curve. Now no one mistake timing with engine run-on/"dieseling"..Engine run-on is mainly caused by the throttle blades being too open, and when combined with low octane fuel becomes a "diesel". On an airboat the load of the prop causes the need for idle circuit metering that no carb manufacturers sell on the mass market. When the throttle blades are too opened to obtain a "good" idle, it signals the secondary/transfer circuit as well as the main circuit.....So when you go to shut it off...It still gets a good amount of fuel and air, and with poor quality fuel..It will diesel as long as there is enough heat in the combustion chamber (Higher static compression ratios make this worse). This is where Waterthunder gives excellent advice...Letting it run will cool chamber temps after a hard run....But ultimitely in my opinion to cure it would be a properly designed carburetor, or a "dashpot"/fast idle solenoid..
Now as for the compression....I think at least one head has been pulled off before and milled, or the engine has some heads that are one-off. You have 2 different static compression ratios in the engine for both sides to be off on compression on a consistent pattern like that. Even if the carb fuel-washed 4 cylinders, they still wouldn't be that consistent on compression, and a dual plane intake sends the fuel mixture to two cylinders on either side from each primary. I honestly think you just have two different heads as far as chamber cc's go...Or maybe a different thickness head gasket etc....Either way, I would bet my last nickel it has had at least one head off of it.
Bottom line on timing and fuel octane...IF the cylinder temps/compression were equal based on your coolant temp...For performance only, I would suggest 93 and 36-38 total advance with all ignition lead in by 1500 RPM. For a ground pounder/ride boat, and 89...I would tend to go 34-36 and have full advance in by 2500. Of course every engine is different, and the load/driving style as well.....I would say that should be pretty safe #s to start by with an aluminum head...It's all a dance...I'm sure Waterthunder, myself, or many other people here will be willing to help you out.
Felber
