thinking about a ratio change.....
jopete
Postby jopete » Wed May 11, 2011 9:16 am
i had a 15' porier [sp] hull with a 454/2:1 reduction. ran ground pretty good, but i wanted more.
was going to switch gear ratio to 2.3 but got stabbed in back at work and sold boat to pay bills.
anyway, has any of you guys run a 14 or 15' workboat [robicheaux/porier type] with a ch-4 reduction in 2.5 or 2.6 or greater?
i may b wrong, but i would think a man could get away with a crate motor like a zz4 or so and still get stupid push on the ground with the higher ratio. i'm not woried about top end in the deep, on plane and stable is good enough for me.
is there a point where it will b too much ratio? my aircraft boat was like a sportscar next to driving the big bus with the bbc. lol
just seems to me that more ratio would be better than going with unreliable engine mods. maybe i'm wrong?
DynaMarine
Re: thinking about a ratio change.....
Postby DynaMarine » Thu Jun 09, 2011 2:44 pm
ZZ4, 2.68 Stinger and a Sensenich "R" and you'll be more than happy
Shane Lavalette
President/Owner
DynaMarine Performance Boats
785.218.9449
www.dyna-marine.com
shane@dyna-marine.com
Ronaldregan
Postby Ronaldregan » Fri Feb 28, 2014 1:04 pm
418,efi, 600 hp ls3, 4 blade r 2.67 belt. Happy now.
15/8 alumitech
scottyroll
Postby scottyroll » Fri Feb 28, 2014 1:50 pm
My sbc355 with 2.68box and 2blade super wide does very well on the ground with my 13.6 cottonmouth hull.
:Scotty-Roll:
FLAwless
Return to “Louisiana Airboaters”
