Shotgun Shells
Texas hunting and fishing.
cummins diesel power
Re: Shotgun Shells
Postby cummins diesel power » Sat Jul 31, 2010 4:32 pm
Back when i duck hunted it was still legal. I havent duck hunted in many years.
I believe in doing what's "ethical" & would not do anything illegal
when it comes to wildlife. I am a avid fisherman & hunter, & don't do anything any of you
wouldn't.
15x7 1974 airgator,500 cadillac dd,74" q series sensenich prop, 1/2" uhmw poly.
18x8 2001 panther, 502 chevy, 2 to 1 century,3 blade 78" stump puller, 1/2" poly
NotAGuide
Re: Shotgun Shells
Postby NotAGuide » Sat Jul 31, 2010 10:53 pm
Just sounded to me like your still using lead on private property. Sorry if I took it the wrong way. Steel shots been mandatory since the 1984-85 State wide if memory serves me correct. There was a year or two the coast was exempt, but I believe it was before '85.
Professional JB Welder
Old 18' American hull, 470CID S&S, Ch3 2:1, 3-blade Whirlwind Whisper Tip
80 panther
Re: Shotgun Shells
Postby 80 panther » Wed Aug 11, 2010 12:15 am
what is sad is you got more kills with the lead and steel makes me get out there and run down the wounded bird. i don't hunt much fresh water but down here the ducks will go under and bite the grass and die never to be seen by you again red heads are bad about but pin tails do it to.use to have a lab that would stick his head under the water and run back and forth till he come up with the duck sure do miss that dog :(
540 mountain motor
Re: Shotgun Shells
Postby 540 mountain motor » Wed Aug 11, 2010 12:20 am
80 panther wrote:what is sad is you got more kills with the lead and steel makes me get out there and run down the wounded bird. i don't hunt much fresh water but down here the ducks will go under and bite the grass and die never to be seen by you again red heads are bad about but pin tails do it to.use to have a lab that would stick his head under the water and run back and forth till he come up with the duck sure do miss that dog :(
Something about the saltwater makes them act like a redfish after being shot.. Or is a case of duck and cover.. Boo I know
18x8 GTO Saltwater Series, 540 MAS/PFI, 82 SW with Stinger 2.55, "540 RAT-N-A-CAGE"
texas_rebel_1980
Re: Shotgun Shells
Postby texas_rebel_1980 » Sun Jan 09, 2011 11:45 pm
i like my Remington Nitro Steel 3" #2 out of my 870. liked my dad's old Wingmaster better, you could hit a bird a mile away with that long barrel on it!
TAA-512
If it flies, it dies
21DiamondB
Re: Shotgun Shells
Postby 21DiamondB » Thu Jan 13, 2011 7:57 pm
Winchester Expert 3" #2's on the coast with the open bays and heavy winds. They are the cheapest best way to go in my opinion.
-------- 16.5 x 8 Diamondback - 632ci - Oxbox 2. 55 - Sensenich 5-Blade JX---------
rost495
Re: Shotgun Shells
Postby rost495 » Fri Jan 14, 2011 10:17 am
Funny that long barrels don't have anything to do much with patterns, energy or MV in the end, but that long barrel makes up for a major flaw that a lot of folks have, not following through.. once you get a long(heavy) barrel moving its hard to stop it.
Anyone shoot the Rem 1700 plus FPS stuff yet? I;ve talke to a few folks that say its a killer.
I swear I HAVE to make myself start reloading before next fall and pattern until I get what I want... but each year I swear, and then buy a case of shells... heck 10 bucks or so ain't so bad....
Return to “Texas”
