need help on prop size
Airboat propeller discussion.
lostcracker2
Post by lostcracker2 »
I hve an angle valve wide deck IO-0360 (F/I 200) what would B a good prop 2 run on a 12'x7' hull ?
gblack15
Re: need help on prop size
Post by gblack15 »
I have the same motor on a 12' 7" Panther, i am running a 72", 5 Blade Warp pitched at 7 degrees.
air-roberts
Post by air-roberts »
i would say a ab200 whirlwind p.m. me for more info
Air-RobertsImage
New & Used PROPs
WhirlWind prop dealer
Tony480
Post by Tony480 »
I would out a 5 blade saber on it fro Sensenich or a 2 blade NGH. And if you ever need repairs or service you don't have to send it all the way to California.And there customer service is the best! :thumbleft:
WhirlWind Propellers
Post by WhirlWind Propellers »
lostcracker2 wrote:I hve an angle valve wide deck IO-0360 (F/I 200) what would B a good prop 2 run on a 12'x7' hull ?
Hi lostcracker2,
For your angle valve O360 (200hp), we recommend the 2-blade 70" Whisper Tip Narrow. This WTN blade is an excellent match for the hp and RPM of your aircraft motor for maximum thrust and performance. The price is $1590 with free shipping and 30 days satisfaction guaranteed, so you can make sure you love the propeller.
We recommend you purchase through one of our dealers for the best service and support.
If you have any questions, please feel welcome to call or email me anytime.
Sincerely,
-Patti
:proud:
DAGWOOD0520
Post by DAGWOOD0520 »
If your looking for speed you can run a 68-70" 3 blade H
if your looking for an all around good ride prop with the best fuel economy a 2 blade 70" NGH has proven to be a real winner.
Finally if you want all of the low end and more of a hunt style prop a 68-70" Q is your ticket.
Hope this helps.
SkinnerBack
Post by SkinnerBack »
My old boat is turning a 68 or 70in Q series sensnitch @ 3150 with the blades set on 2
aherr520
Post by aherr520 »
SkinnerBack wrote:My old boat is turning a 68 or 70in Q series sensnitch @ 3150 with the blades set on 2
I would put a little more pitch in that
aaof member
SwampNinja
Post by SwampNinja »
Oh brother... I have been on the same boat for now 3 months. Now that my build is coming to an end it's crunch time and now I must decide. From talking to experienced people in the field it has come to a conclusion to put either a q series, ngh or 5 blade saber. Now what I'm going through is deciding the prop size. I'm between a 68" and a 70". I like to go really fast but I love to run dry. O boy oh boy. Why can't a manufacture make something that does both. Lol... Good luck bud.
I am here: http://tapatalk.com/map.php?xwlfc0
"It is what it is."
Tony480
Post by Tony480 »
Sensenich does! Call Dan the Airboat man, he will get ya hooked up! Or call down to Sensenich and talk to Darrin. Them guys will point ya in the right direction. I've dealt with them guys a lot and they have never done me wrong!
JAMES
Post by JAMES »
all the prop mention are great the reason i dident go with sensenich this go around is ... ww customer service is great ....
and the #1 thing is their is no middle man i hate that shyt to many people trying to make a buck after everyones cuts and so forth the prices have to increse sensenich had a increse last yr .. DAN TOLD US ALL. but ww did not .. and them being in cali dont mean shyt sensenich is no faster just because they are closer i order my prop from patti and had it at my door 2 days later .. they both are great and i wouldent run no other brand names then them 2...these props dont cost 3000.00 to make were paying for all the R N D ... :wink:
Bruce
Post by Bruce »
seen quite a few 360s with the whirlwind whispertip narrow and all were impressive id call patti if you have any questions or concerns whirlwind is an absolute pleasure to deal with most durable props ive ever ran plus the through bolt hub design makes it so much simpler if you ever need to take the prop off to change alt belt or anything else and i agree with james just because they are in cali that means absolutly nothing hope this helps
-Bruce
12 foot Mamba "The Underdog"
dantheairboatman
Post by dantheairboatman »
70" two blade Ngh is the prop for your 0360! It will get down on a 4cyl. I'll let you try it and see .thanks Dan
Sensenich propellers dealer.
Airboat consulting.
Dan@352 812 2239
jubu
Post by jubu »
Call patti at whirlwind . good service and good prop.and she a lot nicer to talk to.if you notice on Southern Airboats site Tony 480 is full of it. :violent1:
plumcrazy
Post by plumcrazy »
put a water walker cypress on her and be done
SwampNinja
At the end of the day I've figured it's all preference really. Whatever floats your boat.
"It is what it is."
jimmyflfr
Post by jimmyflfr »
Your 0360 on that 10 ft sled will run dry with a 66-70" prop. Or it's a turd! I'd go w a 68" 2 blade and find the best deal. They are all good props
CAPTAIN-D
Post by CAPTAIN-D »
I also have a 200 it's on a DB Ultralight.It originaly had a 68" Cypress.great hole shot in deep water very snappy ran dry with ease.I wanted more low end push so I went to a 72" Q.I do cruise at a lower RPM and move around on the ground at a lower RPM but did loose some snap.I'm woundering now if maybe I would have been better off with a 70" instead of the 72".I live in Louisiana and don't have the luxury of being able to try different props.You guys in Florida are lucky you have access to trying different props on your rigs to find out what works best LOL.From all the post I've been reading it looks like the 70" is what most people are recomending for the 200 HP.I guess eventualy I will have to give one a try.
BlowInIt
Post by BlowInIt »
For me it would probably be the Whisper Tip Narrow maybe even do a 68 or 69" if you want a bit more snap. That prop is a perfect match for a 4cyl and has the swept tip for less noise. IMO the Q series is desighned for 6cyl aircraft and its to much for even a 200 4 banger, yea they can turn them but I think there are better/more efficient choices now. I dont care for H or Ngh's but thats just me.
The Water Walker Cypress blades make for a hell of a 4cyl prop as well but they will be louder in noise.
Then you got the Sabers or the new Whirlwind Razors as well. I bet a 5 blade setup would be a bad dude on that 200 and they get style points too.
todd glover
Post by todd glover »
Well I'll go against the rest I like a 66 inch prop 68 if I have too I run dry not alot I like snap and I love topend I also liked wood until last month 66x42 would work or a 5 bld warp 66-68 good luck I'm sure most props will work great I just prefer a short prop for more topend
southernman13
Post by southernman13 »
Hi lostcracker2,
Sincerely,
For what it worth I didn't like the wt narrow. I tried it and it was snappy but had no midrange. I have the same engine but mines the hio360 helicopter engine. The wt 72" regular blade is what works best for me. I tried the wt 70" cut down regular blade and didn't like it either. To me they cut the good part of the blade off. I would like to c a hub to make it a true 70" not a cut down version. I had a sensinich q 72" and the whirlwind whispertip out performed it. Not trying to start a fight over the ww and sensinich, I'm just statin what works best for me. The 72" wt performs very well but mine is set on like 1050 it ain't got much pitch in it. Thats why I'd like to see how it would do with a smaller hub and regular wt blades.
-Patti
:proud:
Return to “Prop Talk”
