Perfect prop for lyconental
Airboat propeller discussion.
Southernoutlaw
Post by Southernoutlaw » Wed Jun 20, 2012 2:13 pm
I am building a 11'6" aluminum step hull one seater with a lyconental and im probably going with a ngh or q because I want it to have good push as well as response but I would like some opions on which prop I should use
WORK IN PROGRESS: 12" chuck hawk step hull, back seat driver, conduit rigging, lyconental 6 cylinder, 2 blade ngh prop
DannySauls
Post by DannySauls » Wed Jun 20, 2012 2:15 pm
Tell us a little more about the motor? What diameter would you prefer if there are any limitations
Southernoutlaw
Re: Perfect prop for lyconental
Post by Southernoutlaw » Wed Jun 20, 2012 2:26 pm
The motors apart now and I havent run it yet but nothing larger than a 72" prop
aherr520
Post by aherr520 » Wed Jun 20, 2012 2:32 pm
if you can get at least 200HP out of that motor I would go with the NGH it will give you what your looking for
aaof member
Southernoutlaw
Post by Southernoutlaw » Wed Jun 20, 2012 2:34 pm
Thanks thats what I was leaning twards
Southernoutlaw
Post by Southernoutlaw » Wed Jun 20, 2012 2:41 pm
Should I get a two or three blade ngh
aherr520
Post by aherr520 » Wed Jun 20, 2012 2:49 pm
two blade,70'' or 72'' great all around performance or you can go with a 5 blade saber depending on how HP you will have,I am going to build a 4 banger with turbo and might go with the saber
aaof member
Southernoutlaw
Post by Southernoutlaw » Wed Jun 20, 2012 2:54 pm
Its going to have alot of hp so ill go with the 72 ngh thanks guys
DannySauls
Post by DannySauls » Wed Jun 20, 2012 3:09 pm
If you ever want to try a whirlwind the narrow blade in either a 70" or 72" 2 blade would be pretty wicked or if your feeling frisky the razors a sharp performing propeller with some serious snap and top end!
Tony480
Post by Tony480 » Wed Jun 20, 2012 3:52 pm
Is it a 6 cylinder or 4?
Southernoutlaw
Post by Southernoutlaw » Wed Jun 20, 2012 4:04 pm
6 cylinder
DannySauls
Post by DannySauls » Wed Jun 20, 2012 4:12 pm
What kinda power is a lot of power?
Tony480
Post by Tony480 » Wed Jun 20, 2012 4:14 pm
6 blade saber. I hope it's stronger then the few I have seen.The couple I seen were turds.
Qwikdiesel
Post by Qwikdiesel » Wed Jun 20, 2012 4:19 pm
IMO, If your wanting to race it 72" is to long.
Southernoutlaw
Post by Southernoutlaw » Wed Jun 20, 2012 4:45 pm
Its going to be a ride and race boat boat
cont520
Post by cont520 » Wed Jun 20, 2012 6:14 pm
Must be some top secret classified stuff noones ever tried before. Hell I would go with a 70" 6 blade saber or razor prop plenty of low end and runs out well
Robert Mccormick
Plant City Florida, Toxic calls Pro staff and proud member of usfth
Ultimate Shot Productions prostaffer
Return to “Prop Talk”
