0290 props?
Airboat propeller discussion.
hayesboys352
0290 props?
Post by hayesboys352 »
I've got a 4 warp drive on my 0290 what's the best prop to run on this motor for running dry along with a fair top end and little prop noise warp does good but lord have mercy the noise when giving her hell lol
Re: 0290 props?
Post by Deano »
Water Walker . . . Cypress Series.
http://www.airboatprops.com/Cypress%20Series.htm
Olf Art
Re: 0290 props?
Post by Olf Art »
Deano, if you were gonna put a lumber prop on one of them about what do you think would work?
AV8R040
Re: 0290 props?
Post by AV8R040 »
I just bought a 68" whirlwind super snapper to put on mine. I only bought the 68 because I plan to upgrade to a 360 soon and wanted enough prop for it. If it is too much Patti at Whirlwind told me she could cut it down to 66 without much issues. I have a 66 4blade warp on it now and it doesn't like running much dry. Had a 66x32 stick prop on it and it ran great. I have been told a 66" h would be great on it also. I have also heard the 66 signature series is a good one too.
Good luck. What kind of hull is yours on?
Im more concerned about bottom end than speed. You get the speed with the warps.
Nugent/Palin 2016
Re: 0290 props?
Post by Deano »
Olf, It's been a long time ago but I think it was a 68x32 that he had before it was replaced with the Cypress.
Prior to that I think it was like a 60x38, not sure, but it wasn't quite enough.
The 68x32 was much better, but maybe a little big. With the Cypress it was like having a different engine.
Very similar to when I took off the woddie and put Signatures on my Caddy.
Sorry, I know that wasn't much help, don't remember as much as I used to.
There just isn't any denying the adjustability of a composite.
diamondback0320
Re: 0290 props?
Post by diamondback0320 »
Ww cypress is a good all around prop,would prob def wake it up!
hayesboys352
Re: 0290 props?
It's a 0290 with 160 rods 180 sump on a 2009 11' lake pan hull yes warp flys and runs good yes does run dry with warp but I want that sudden stap without having to twist it up like the warp has to so yes I'm gonna chech in to everyone's opinion on this so thanks for them
wes30
Re: 0290 props?
Post by wes30 »
Water walker all the way,u won't be disappointed
Return to “Prop Talk”
