Q series on a 180
Airboat propeller discussion.
newoldglory
Q series on a 180
Post by newoldglory »
Anyone running a Q on a 180? If so, what's you're input? I'm on a stossil 12'
To open ones eyes, you must let them see!
Remember; sometimes it's better to be thought a fool than to open you're mouth and prove it.
deepsea diver
Re: Q series on a 180
Post by deepsea diver »
Not me! I run a 70" Q on a 12 ' sled powered by a h2AD (160). I ran. 70 " 5 bld warp drive and a NGH.
The "Q" has way more grunt and push . It has better cruise and better mpg. On my rig the Q beat out the other 2 . The NGH revved up faster but did not have the push. The WD was smooth but had the least amount of low end push. We ran all 3 blades on two boat, both with only H2AD's . The Q is on both boats today. A high top end is not what I am looking for. More grunt and better MPG is what the Q brings to the table. However things may change with the addition 20hp. If we where closer I would let you put the Q on your boat and test it out. Up here in central Fl you see lots of 4 bangers running WD
, Cyprus, Whisper tips, and Q's. Gerald, what expectations are you looking for in a prop? V/R DSD
southernman13
Post by southernman13 »
Buddy of mine has one on a boat I built him, it's a stock 180 runout with a 72" Q runs super. Got another buddy runnin a 70" Q on a 12'6 alumitech with a strong 190 it runs good but I think he needs the 72"Q someone else talked him into the 70". I've tried the 70q's and 70" whirlwind wide blade and narrow blade I didnt like any of the 70" props, IMHO they weren't any snapier except the narrow blade whirl wind and none of them pushed as good as the 72's
newoldglory
I favor the Q since I tryed it on a 220gpu & big O. This stossil came with the warp, which is a great prop but my ears and mind can't take the noise anymore. Just wanted input from someone with the Q & sled setup. Now, 70 or 72?
jdr422
Post by jdr422 »
Hey guy im kinda new ti the scene Just asking a question here but what exactly is the difference goin from a 70 to a 72 what arethe advantages.
schmidtav2
Site Supporter - VII
Post by schmidtav2 »
We've put several 68" Q series props on both 180's and 200's with good success, also have had good luck with the 70" Whirlwind whisper tip prop.
Dirt Cheap
Post by Dirt Cheap »
Have a 70" Q on a 11'8"x7'4" open hull with a 180 and it works good for push.
swampman
Post by swampman »
i have a 180 with a 70 in h turns 2850. is the Q better than the h????
doubledown0540
Post by doubledown0540 »
i would put a 70 cypress series on it. you will get the best push from that prop
13ft Rivermaster with poly
sv 540 with mid compression pistons
72 in water walker signature series
rigged for me and the wife
Completely built by me.
fl cracker
Post by fl cracker »
I sold my Q to get the NGH, The NGH has just as good of push as the Q and has better mid & high end range. It is also quieter. The absolute best thing to do is get both blade types and run them and make your own decision ! The Q falls flat on its face on the top end.
" I have two guns...
One for each of you "
2017 Al David / stroked LS
swampman
Post by swampman »
thanks i will check it out.
Return to “Prop Talk”
