Water in R blade
Airboat propeller discussion.
Ugmo#1
Water in R blade
Post by Ugmo#1 »
Water in R blades what can I do it's Vibrating motor bad :banghead:
billybob
Re: Water in R blade
Post by billybob »
Take it out of the hub and send it to Sensenich and have it repaired correctly.
I do all my own stunts!!!!!!
mike99705
Post by mike99705 »
How the hell does water get in the blade unless you knocked a hole in it?
8 x 15 alumitech 383 mas from gto 3 blade r 2.3 belt
undicided
Post by undicided »
My buddy had the same problem with his R series that was less than 6 months old. After a phone call he was told not to leave the prop vertical when the boat is sitting. I didnt see where that caused it
billybob
Post by billybob »
It could be several different problems. I had the problem with my h blades. The harmonics caused a crack in the plug and the blade at the bottom would get water in it while not running. V
Duece
Post by Duece »
I had TONS of issues with this. Sensnich finally fixed it by sending me new blades, but it sucks big time. My hub would completely fill with water it out in a rain storm. They sent me new hub and blades and made things right (which is what they do, they are VERY VERY good folks there at Sensnich). They also recommend that you silicone the hub too.
Duece
"Welcome to the Dark Side..."
BluByU2
Post by BluByU2 »
I just had that problem with my NGH (one blade), and I called Sensenich. I was told to stand the blade vertically (hub down) in the hot sun which will increase pressure within the blade, and force the water out from where it entered. Another suggestion was to drill a small hole in the data plate (avoiding the data), and stand up as described above for a couple of days. I did this, but I still had to shake the remaining water out of the blade. Once all the water was eliminated, place a small dab of clear silicone in the hole, and the hub can reassembled on the boat. When you have the correct pitch, you can seal the hub, and around the blades with clear silicone to prevent water from entering again. It worked for me.
harley
Post by harley »
BluByU2 wrote:I just had that problem with my NGH (one blade), and I called Sensenich. I was told to stand the blade vertically (hub down) in the hot sun which will increase pressure within the blade, and force the water out from where it entered. Another suggestion was to drill a small hole in the data plate (avoiding the data), and stand up as described above for a couple of days. I did this, but I still had to shake the remaining water out of the blade. Once all the water was eliminated, place a small dab of clear silicone in the hole, and the hub can reassembled on the boat. When you have the correct pitch, you can seal the hub, and around the blades with clear silicone to prevent water from entering again. It worked for me.
X2 DONE THE SAME THING WITH MY R BLD AND ALL IS FINE SO FAR. :thumbleft: :rebel:
14x8 Diamondback / SBC Power.
"ALL THROTTLE NO BOTTLE"
ptr34
Post by ptr34 »
It only takes a tiny pen hole and water to sit in the plug with all the rain we have been getting to get water in it. We have made a new plug that we are using now to help improve this issue.
tons videos on YouTube ptr34
keebo
Post by keebo »
Or ya could get a whirlwind :D :D :D Sorry had to say it :blackeye: LOL
But really Sensenich props are good and good folks there they will help ya out.
:old_glory: :florida: :GA:
Ugmo#1
Post by Ugmo#1 »
I got it fixed I set it in the sun upside down blowed all the water out of it appreciate all the help Then I put silicone around the hubs in the blades
bman
Post by bman »
You can always cut the blade tip off 8) This way when you start the motor up all the water will sling out the end of the prop :wink:
Disclaimer: Not responsible for any damage caused by my bad advice :lol:
B-White
Post by B-White »
[quote="keebo"]Or ya could get a whirlwind :D :D :D Sorry had to say it :blackeye: LOL
:thumbleft: :thumbleft: :thumbleft: :lol:
Devil in the Bottle 83 ProMod
Marsh Master Step
Carbon Fiber Rudders by:HAMMERHEAD AVIATION.com
Prop is NOTHING BUT A WHIRLWIND!!!
RAZORX
Return to “Prop Talk”
