Neebie with prop questions
Airboat propeller discussion.
jeepster71
Post by jeepster71 »
Hi there I am new to airboats and
Bought a 0-290- d for $600 and going
To put it on a 11.5 ft by 80" across top
airboat hull that I have so I need help on
What prop and how big and I will also be
Put uhmw on the hull as well thank you for
Help and any info is greatly appreciated
REAL 7.3
Re: Neebie with prop questions
Post by REAL 7.3 »
My 10'6" Gillieo with a 0290 D2 had a 66x34 wood prop from sensnich
11' Gillieo PE90
ptr34
Post by ptr34 »
66" NGH on it. Great push
tons videos on YouTube ptr34
jeepster71
Thank y'all I have to rebuild everything and
I want to make sure that I build the cage
Big enough and I will try to get some pic
On here and thanks again
akblackdawg
Post by akblackdawg »
Jeepster, welcome to SA and the forum (whats a neebie). Bud
jeepster71
I meant newbie as u u can tell my spelling
Is not very good :)
Return to “Prop Talk”
