68" 3 blade whirlwind on 220 gpu
Airboat propeller discussion.
Diamondjphotography
Post by Diamondjphotography »
How would a 68" 3 blade whirlwind prop do on a single mag 220 gpu?
clownpuncher321
Re: 68" 3 blade whirlwind on 220 gpu
Post by clownpuncher321 »
This is thomas I see your thinking about getting back into the airboat world and 68 three blade should do fine on a 220
Diamondjphotography
Thanks Thomas.
Diamondjphotography
Not a lot of feedback from folks on this question Thomas. That can't be good. Do you know anyone that's ran this prop on a 220?
GeeLeDouche
Post by GeeLeDouche »
I have no experience with this prop or motor, but if I were to guess I would say that a 3 blade would be a little to much prop for a single mag 220. I would think a 2 blade 70 inch blade would be a better setup, but again, that's just a guess. if you go for it, let us know how it works. :D
Bruce
Post by Bruce »
68 three blade should do well on it
12 foot Mamba "The Underdog"
Diamondjphotography
Thank you for your input.
AV8R040
Post by AV8R040 »
I ran that same setup on a 220. It ran pretty well. I think I had it on about 13 in the marks on the hub.
I couldn't fit any larger in my cage on the boat and a 2 blade couldnt crank enough pitch into without hitting the alternator on my setup.
Nugent/Palin 2016
B-White
Post by B-White »
Before you take all these suggestions.....it would be nice to know what kind of blades??
Devil in the Bottle 83 ProMod
Marsh Master Step
Carbon Fiber Rudders by:HAMMERHEAD AVIATION.com
Prop is NOTHING BUT A WHIRLWIND!!!
RAZORX
mev3rd
Post by mev3rd »
http://www.southernairboat.com/photopos ... 24/cat/500
Here is a link to Cowtown's 220 with a 3 blade.
:florida:
coopb6
Post by coopb6 »
You need to be specific on which 3 blade. I ran a 3 blade excaliber. Plus theres wider blades that you wont be able to run.
Please be specific for a better feed back
Diamondjphotography
I believe super snapper. I spoke with patty at whirlwind a bit ago and she said it will do good. Only one way to find out! Thanks for the feed back
jopete
Post by jopete »
i always read on here that a paddle prop will snap the crank on a gpu. i'd like a 3 blade for mine. should run alot smoother than the 2blade 70'' whirlwind i run now.
Return to “Prop Talk”
