sensenich NGQ
Airboat propeller discussion.
gig_em13
sensenich NGQ
Post by gig_em13 »
I just bought a NGQ new from sensenich for my close to stock 350 SBC and I put it on the number 2 pitch mark only got 2200 rpms moved it to number 1 and got 2600 it pushes really good on the grass but I haven't water tested it yet so should I try to swap to the ngh or can I put a little under the number 1 mark? Any help is appreciated!!
14'x7.5' gilleo 220gpu 72" whispertip!
ptr34
Re: sensenich NGQ
Post by ptr34 »
Yes u can go under one. But I would see how it ran in water. First it may run great and get great fuel mileage there.
tons videos on YouTube ptr34
deepsea diver
Re: sensenich NGQ
Post by deepsea diver »
I am spinning a 70 inch Q with a 0320 H2AD (160 hp) at just under the 2 mark at 2700. Pushes very good and has nice cruise at 1800 to 1900 rpm. Over 4 miles per gal. You might want to back off a little and spin it to 3000 rpm. It you are not happy then asked prop dealer to left you try another prop. The good thing is its moving on the ground. The 70 inch Q on the H2AD, has more push than my Chev 400 and 72 inch 5 blade warp drive (direct drive)
I bought the 70 inch NGH then up graded to the Q. The NGH had quick responce, less push and higher cruise, good luck
fl cracker
Re: sensenich NGQ
Post by fl cracker »
Deep sea , the Q is not an up grade from the NGH. :lol:
" I have two guns...
One for each of you "
2017 Al David / stroked LS
Re: sensenich NGQ
You never mentioned the size of the prop?
I am spinning a 76 inch NGQ direct drive on my Caddy, the boat is a 16ft ride boat that is heavy as a tank. The push that prop generates around 2400 is awesome. I would try it on the water and see but my guess is you will only come up about 50 or a 100 rpm. That's what mine did but every engine and boat are different.
schmidtav2
Site Supporter - VII
Re: sensenich NGQ
Post by schmidtav2 »
The 2 pitch mark on a Q blade is different than the 2 pitch mark on the NGQ, they are completely different blade designs and the RPM's are different with the same pitch mark set. We find that we set most NGQ props between 1 1/2 and 2, depending on length of the prop and the type and HP of the engine. My advise would be to test it as you have it set to see if it performs good, I think it will.
fl cracker
Re: sensenich NGQ
I was at the river last week and a buddy tried to climb BS Hill and got stuck at the bottom. He's got a lazer with a spacer jug 300 , poly and a 74" Q. He was doing circles on the flat ground. I come through there with 4 on the boat still blipping the gas with the Ol NGQ right to the top.
GeeLeDouche
Re: sensenich NGQ
Post by GeeLeDouche »
May I suggest trying to up the HP/torque of your 350 motor instead of going lower..?? it may be a more viable option?
ptr34
Re: sensenich NGQ
Post by ptr34 »
I'd run boat first. Doesn't really matter what rpm it turns as long as it runs good
aherr520
Re: sensenich NGQ
Post by aherr520 »
fl cracker wrote:I was at the river last week and a buddy tried to climb BS Hill and got stuck at the bottom. He's got a lazer with a spacer jug 300 , poly and a 74" Q. He was doing circles on the flat ground. I come through there with 4 on the boat still blipping the gas with the Ol NGQ right to the top.
That's because you have poly butter on your boat :lol:
aaof member
fl cracker
Re: sensenich NGQ
I can assure u that had nothing to do with it! His boat had butter too! :lol:
aherr520
Re: sensenich NGQ
Post by aherr520 »
I feel left out I'm the only one without butter and an NGQ :(
aaof member
ptr34
Re: sensenich NGQ
Post by ptr34 »
We can fix that for u.
Bruce
Re: sensenich NGQ
Post by Bruce »
aherr520 wrote:I feel left out I'm the only one without butter and an NGQ :(
nah ur not the only one
12 foot Mamba "The Underdog"
Andrew McD
Re: sensenich NGQ
Post by Andrew McD »
Water Walker Props, Inc.
(863) 676-PROP
plumcrazy
Re: sensenich NGQ
Post by plumcrazy »
:slap: Water Walker NO butter required :thumbleft:
rdr822
Re: sensenich NGQ
Post by rdr822 »
ThTs the same thing i was thinking. Just get a water walker.
Tony480
Re: sensenich NGQ
Post by Tony480 »
No just a new crank
rdr822
Re: sensenich NGQ
Post by rdr822 »
I've had one for 15 or 16 years on two motors. No crank problems yet
signcoc43
Re: sensenich NGQ
Post by signcoc43 »
No poly butter needed with my "Q" !!!!!
12 foot hamant fuel injected pe-90 520 conversion swinging a 68" ngq!!
" Yes my boat is slow!!!"
signcoc43
Re: sensenich NGQ
Post by signcoc43 »
BAD ADDICTION
Re: sensenich NGQ
Post by BAD ADDICTION »
20 or so water walker props in mims no issues with cranks. And u can't beat the push. I do like the r blades on a gear box motor though. To each is there own.
WE NEED IT WE BUILD IT!!!
Geared supercharged 0480 on 13 Hamant swinging 78" r blades. !!!
Tony480
Re: sensenich NGQ
Post by Tony480 »
Yep....and as far as poly butter....I tried it cause it was gave to me. I wouldn't give one red cent for it. It doesn't help one bit in the nasty sticky green. Just ask sidejobs or fl cracker...they both tried it and said the same thing. But to each his own...
gso480jr
Re: sensenich NGQ
Post by gso480jr »
Hey! I feel left out too? Well I ain't got no NGQ or butter but I take my Q with poly anywhere anyone else can run. Same crank for 12 years too. :lol:
Return to “Prop Talk”
