Trying to decided on what prop
Airboat propeller discussion.
SkinnerBack
Post by SkinnerBack »
I'm trying to decided on a new prop to go with..... I have a spacer jug injected 540 with 11to1 compression, I just had a sabor blade break off close to the hub for no rhyme or reason so it has me scared of them small blades now..... So I'm looking for something diff, my motor loves high rpms, it doesn't make any power when you choke it down to 2750 2800, she likes singing around 3000 or so. So with that being said I'm open for opinions, keep in mind the is gonna be a ride boat not a race boat..... So I need some good push, I will go with any prop maker I'm not set on a particular company!!!! Thanks in advance......
coopb6
Re: Trying to decided on what prop
Post by coopb6 »
Heard alot of good things about them ngq's terry farkas could set u up with one
SkinnerBack
Maybe one of the prop gurus will chime in cause my understanding of the NGQ is that it's much for high rpms....... Which where I make a lot of my power.... Cause when I choked my motor down to 2750 on the trailer it was a dog @ the lake......
blowboatbandit
Post by blowboatbandit »
Call David at Water Walker. Im sure he will have what you need.863 676 prop.
Doing what I do best.. showing off..
SkinnerBack
blowboatbandit wrote:Call David at Water Walker. Im sure he will have what you need.863 676 prop.
Thanks blowboat
fl cracker
Post by fl cracker »
Pretty simple decision. If the motor has balls put a 76" NGQ, 12" wide your not gunna find better low end grunt than that.
" I have two guns...
One for each of you "
2017 Al David / stroked LS
farmboy
Post by farmboy »
Billy if it was me I'd say either a 3-blade NGH or a 2-blade NGQ . I bet your boat would run great with either or... Get with terry he will set you up in the right direction.
SkinnerBack
farmboy wrote:Billy if it was me I'd say either a 3-blade NGH or a 2-blade NGQ . I bet your boat would run great with either or... Get with terry he will set you up in the right direction.
Thanks Cracker & Kevin...... Just got a little thinkin to do my buddy has an NGQ I can put on her & try just gotta find a an NGH to try....... Thanks to both of you again!!
bowhunter
Post by bowhunter »
I JUST PUT A 74 NGQ ON MY 13 FT DIAMONDBACK WITH 520 FUEL INJECTED ANGELVALVE IN MAN ITS GOT SOME BALLS IM VERY HAPPY SO FAR LOTS OF LOW END GRUNT .
B-White
Post by B-White »
You can also think about the Excalibur if your scared of the smaller blades. The shank size is bigger than the sabers but smaller than the big blades. They also have a core composite structure. You can spin them on up a little more. Stroked470 just put one on a nasty AV 540...See what he thinks of his.
Devil in the Bottle 83 ProMod
Marsh Master Step
Carbon Fiber Rudders by:HAMMERHEAD AVIATION.com
Prop is NOTHING BUT A WHIRLWIND!!!
RAZORX
SkinnerBack
B-White wrote:You can also think about the Excalibur if your scared of the smaller blades. The shank size is bigger than the sabers but smaller than the big blades. They also have a core composite structure. You can spin them on up a little more. Stroked470 just put one on a nasty AV 540...See what he thinks of his.
Thanks Bwhite, iv ran warp drives & the sabor on this boat but it's was just weird how it broke, kinda got me leery of them now cause it broke with no rhyme or reason...... But I deff want to try several props before I buy one, thanks for the info!!
fl cracker
I seen your boat on FB. I didn't know you bought "Dirtpoors " boat . That's a rank bitch!
SkinnerBack
Yes sir that the one i bought!!! I love that thing but Im changing the whole boat............. selling the hull & metal works & goin to a bigger hull & but still a light set up!!!!!
Bruce
Post by Bruce »
SkinnerBack wrote:Yes sir that the one i bought!!! I love that thing but Im changing the whole boat............. selling the hull & metal works & goin to a bigger hull & but still a light set up!!!!!
if u love it why u changin it that boat runs good
12 foot Mamba "The Underdog"
SkinnerBack
well let me make it a little clearer, love the power it has hate that none handleing little hull & the ole lady hated it to so decided to change it up a little, the boat runs great fast as all get out but that hull is entirely way to thin for the riding i like to do & didnt realize it when i was lookin @ the boat. I makin it into more of a ride boat with a rank ass motor & not the race boat set up that it is......
Bruce
Post by Bruce »
ya know i tried buyin that set up when he first got another hull but he was set on puttin a motor on it and sellin it whole lol
SkinnerBack
If i wasnt planning on having kids & what not in a few yrs then i would make myself get used to driving that hull but im going back to a lazor & a little bigger but its still gonna be a light set up
ptr34
Post by ptr34 »
Let me know . I got 72 to 76 size of ngq. And I will have a new hull soon to consider ;)
tons videos on YouTube ptr34
Post by kwanjangnihm »
Terry you still running one of William's laser hulls?
ptr34
Post by ptr34 »
Right now . But getting a new dyna marine opwn hull
aherr520
Post by aherr520 »
ptr34 wrote:Let me know . I got 72 to 76 size of ngq. And I will have a new hull soon to consider ;)
so how much is a 74'' ngq and is it any smoother then the Q?
aaof member
sidejobs
Post by sidejobs »
Try a 4 blade Excalibur ! As bwhite stated they are larger than the sabers. They love 3000 rpm and I'm extremely satisfied with mine.
________________
IDIOT !
lycominman160
Post by lycominman160 »
Billy get with William he's a sensenich dealer and has the ngh ngq saber anything you wanna try any size and guaranteed you get a good price and installation of the prop also
mwood7800
Post by mwood7800 »
I have a spacer jug av 540. Just went from a 6 blade warp to a 3 blade q. The q has more low end but damn loud, I already had a mullet in the prop and it did some damage, the warp would have had no damage, all in all I see little improvement. The q is not as smooth for sure. My girl friend really hates the q noise.
Return to “Prop Talk”
