Reduction change
Airboat propeller discussion.
bbboswell
Reduction change
Post by bbboswell »
Currently running a 496, 2:1 reduction. Max push occurs at 4600 engine RPMs which matches the advertised max efficient prop RPM advertised by Water Walker.
I am in what Water Walker says is the sweet range of prop adjustment but have some adjustment left.
Question is, if I go to 2:3 reduction will I outgrow,this prop or will I be able to add pitch and gain thrust at a given RPM?
My engine is purpose built to,achieve max HPs & torque by 5200 RPMs
skinny99
Re: Reduction change
Post by skinny99 »
What prop? How many blades? What length?
bbboswell
Post by bbboswell »
skinny99 wrote:What prop? How many blades? What length?
Power shift - Power Plus series. 78" - 3 blade
About 3/16" of pitch left to stay within what is said to be optimum.
Return to “Prop Talk”
