70" water walker on a 180?
Airboat propeller discussion.
chance
Post by chance »
Just picked up a 70" water walker 2 blade and was wondering if it was a good combo for my 180 lycoming. I had a 5 blade warp and was not impressed . Boat would not run dry even on wet grass. It's on a old Thurman full deck with poly. Basically I am looking for more push I really don't care for top end racing.
russellreese87
Re: 70" water walker on a 180?
Post by russellreese87 »
I run a 70" signature series on my 0340 and it pushes really well and cruises. Still snappy but no race boat snap
lycoming 170 angle valve on a 12'x7 1/2 hammant
signcoc43
Post by signcoc43 »
It will push it
12 foot hamant fuel injected pe-90 520 conversion swinging a 68" ngq!!
" Yes my boat is slow!!!"
Stewie
Post by Stewie »
I'm turning a 69in Q series on my 160 h2ad and it's no racer but pushes anywhere with no problem. :old_glory: :florida: :rebel:
diamondback0320
Post by diamondback0320 »
68 or 70in ww cypress series will definitely push good!
juice
Post by juice »
chance wrote:Just picked up a 70" water walker 2 blade and was wondering if it was a good combo for my 180 lycoming. I had a 5 blade warp and was not impressed . Boat would not run dry even on wet grass. It's on a old Thurman full deck with poly. Basically I am looking for more push I really don't care for top end racing.
That 7.3 in your truck with a gear box sounds like a win
Thunder200
Post by Thunder200 »
I have a70in. W.W. Cypress on a 200hp 4cyl. and it pushes like a beast. Top end speed not all that impressive but a dont race so doesnt bother me. Good on fuel consumption. You will like it! Snappy and will push big time!!!
NightRider
Post by NightRider »
If your boat wouldn't run dry on wet grass before, don't expect the water walker to be a miracle maker. Warp drives may not be the best pushing props, but sounds to me like you have other issues.
IRAA, KRVSA, FAA.
Seven3
Post by Seven3 »
NightRider wrote:If your boat wouldn't run dry on wet grass before, don't expect the water walker to be a miracle maker. Warp drives may not be the best pushing props, but sounds to me like you have other issues.
I agree. My previous boat was a 12x6'8 Thurman with just a little 0-320 150hp swinging a 3 blade Excalibur. It would run dry no problem with myself, 35 gallons of AV gas, and a cooler. Add another passenger and she didn't do as well, but it would still go. You've got a lighter boat and 30hp more, the warp should move it. How is your poly?
Gary S
Post by Gary S »
What are you turning the warp. You might need to add some bite.
Return to “Prop Talk”
