Wood vs carbon dd caddy
Airboat propeller discussion.
duckhunter1984
Post by duckhunter1984 »
I have been told by two people that a wood prop will push harder that a new carbon prop.... I have a wood prop now on my dd 350 now I'm switching to a caddy 500 and am getting ready to buy a prop .... I was leaning towards a whisper tip but will wood push better? Thoughts??
swampfox
Re: Wood vs carbon dd caddy
Post by swampfox »
Wood props push real good. I will not disagree. But compared to a whispertip wide blade, it will outperform it n every aspect. IMO
Diamondback 0235c sprayer/ predator gore and powerplant??? Stroked out 65 continental :)
Striker543
Post by Striker543 »
Putting a 3 blade H on my old man's boat when they were first getting popular ten years ago really woke the boat up. The performance was night and day compared to the wood paddle we had on there.
digginfool
Post by digginfool »
You should talk to KoreyC. (include the 'period' on his username). He just switched to a bowtie Excalibur on his Caddy boat and loves it.
sidejobs
Post by sidejobs »
Do a search under prop talk. Lots of good info.
________________
IDIOT !
Olf Art
Post by Olf Art »
Other advantages, in addition to the fact that the Whispertip is infinitely adjustable, are that it will be impervious to moisture
compared to the wood prop, and lighter. A lighter boat is always good, and a lighter prop will also be easier on that 'ol
Caddy engine's rear main bearing.
Just my thoughts ...
WhirlWind Propellers
Post by WhirlWind Propellers »
The wood vs. composite adjustable propeller question has been asked a number of times. Here's a similar thread from 2011/2012:
https://www.southernairboat.com/phpBB3/ ... ilit=+wood
And an excerpt of my reply:
Material substrate has nothing to do with imparting momentum on the surrounding fluid medium. In other words, the air doesn't know if you have a wood prop or a composite propeller. But, there are a number of advantages to composite propellers.
Composite propellers offer improved Durability, Safety, Longevity, Balance, and Adjustability. With adjustable pitch, you have the choice to set up for max thrust at full throttle, or to increase the pitch if you want to lower your cruise RPM for even better fuel efficiency. And, if you ever make changes to your engine, you can typically adjust the prop to match.
In theory, you could get lucky and have a perfectly sized/pitched wood propeller for your engine's RPM and HP, but it doesn't happen that often. And, as I noted above, there are many other advantages in spending the additional money on a composite adjustable propeller.
For your dd caddy, your best choice is our 2-blade 72" Whisper Tip propeller for $1690, or the ultimate no-compromise 4-blade 72" Excalibur propeller for $2290. Either one would most likely out-perform your wood propeller in every way.
Please feel welcome to contact me anytime with questions. Best to you.
Sincerely,
Patti
:proud:
Olf Art
Post by Olf Art »
I've missed Whirlwind's comments on here, Patti. Hope y'all have a blessed Christmas. :)
Yes, sorry. Having a 1 year old takes up much of my evening time that used to be spent online. I've missed the time to get on SA as well. I hope everyone knows they can always call or email me with questions.
Merry Christmas and Happy New Year!
Sincerely,
Patti
No comparison! My NGQ pushes like it has 4x4
Don't listen to anyone who says a composite prop is no good on a DD Caddy, that's bad data!
duckhunter1984
I ordered a 72" whisper tip last week. It is supposed to be here Friday!!! I have my new caddy 500 motor on my boat. I am excited to hop in my big 18x8 footer with the new engine and prop....should be a lot different than that old 350dd!!!!!! Thanks Whirlwind for your help.
Good luck Duck!
duckhunter1984
SWAMPHUNTER45 wrote:Good luck Duck!
Thanks!!! :o
Return to “Prop Talk”
