Time for prop
Airboat propeller discussion.
Gary S
Time for prop
Post by Gary S »
Almost time for a prop on my new boat. 11 foot Don Davis with a 0320. I run a Q on the boat I have now and I am satisfied with it. It pushes great and it goes fast enough for me. Have heard good things about whirlwind. What does Whirlwind make that is comparable to the Q. I am more concerned with low end push and cruise than top end.Anyone go from Sensenich to Whirlwind?
Scarecrow
Re: Time for prop
Post by Scarecrow »
Gary if that is a 68 in. :salute: :rebel: in good shape PM me a price if you decide to sell it. THANKS
Seven3
Re: Time for prop
Post by Seven3 »
I had the 66" Whirlwind Excalibur on my old 320 powered Thurman. The push was there. It would run dry pretty well for a 12 footer, especially since it only had 150hp. If I bought another 4 cyl boat, I'd buy the Excalibur again.
fl cracker
Re: Time for prop
Post by fl cracker »
You should look into the 68" NGQ. You could reuse your existing hub , it is night and day compared to the Q.
" I have two guns...
One for each of you "
2017 Al David / stroked LS
upstackkid92
Re: Time for prop
Post by upstackkid92 »
I have a 170 and I ran the 68" ngq and wasn't impressed neither was my buddy with his 320 boat. I would demo it first to see before you buy it, I also ran the ngh in 68" and the cypress in 68" im currently running 69" bowtie with razor blades and love it much smoother than the two blades and has more snap, also its easy to pitch and take on and off and if I damage a blade I can get a new one shipped for free for 300 dollars.
flcracker9
Re: Time for prop
Post by flcracker9 »
upstackkid92 wrote:I have a 170 and I ran the 68" ngq and wasn't impressed neither was my buddy with his 320 boat. I would demo it first to see before you buy it, I also ran the ngh in 68" and the cypress in 68" im currently running 69" bowtie with razor blades and love it much smoother than the two blades and has more snap, also its easy to pitch and take on and off and if I damage a blade I can get a new one shipped for free for 300 dollars.
Not trying to steal the thread, but how do those Razors push on the low end? Looking for options to replace my warp
upstackkid92
Re: Time for prop
pretty darn good I turn 2700 have them all pitched at 7.5 the bowtie setup acts like a wide blade so I have good low end but its still snappy and smooth like a warp and its not loud either, however im not sure what the real gains are over the standard warp blade I went straight to the razors on my boat.
signcoc43
Re: Time for prop
Post by signcoc43 »
I went from a 70" q to 68" ngq and love the difference!! Running less pitch and getting better fuel usage with the ngq
12 foot hamant fuel injected pe-90 520 conversion swinging a 68" ngq!!
" Yes my boat is slow!!!"
ptr34
Re: Time for prop
Post by ptr34 »
68"NGQ is awesome prop for 4 cylinder. I have one we can test.
tons videos on YouTube ptr34
Return to “Prop Talk”
