Razor X Hub from Whirl Wind Propellers
Airboat propeller discussion.
WhirlWind Propellers
Post by WhirlWind Propellers »
We have a new complete hub system available for the Razor X propeller blades.
:: The Razor X hub is available in 3, 5 and 6 blade configurations for 66" to 74" diameters.
:: The hub plates are finished with a cool carbon fiber graphic that also serves to keep your torque specs visible whenever you need them.
:: The new Razor X™ hub is highly engineered, with blade blocks made from strong and light billet aluminum.
-Patti
:proud:
PAINKILLER
Re: Razor X Hub from Whirl Wind Propellers
Post by PAINKILLER »
That's very cool (would also like to say a very big thank you for answering my questions you have a new customer
MATTHEW 25:35-45 LS 406 82 4bld WaterWalker falcon 2.68 ox box
LS 427 80 3 Bld WaterWalker Maximus 2.68 ox box :rebel:
dodobird
Post by dodobird »
very nice :florida:
13' laser 360sbc oxdrive 2.68 .... 80" 3 blade whispertip ex :florida:
PeaRiverOpossum
Post by PeaRiverOpossum »
What is the price? I'll be calling soon.
PeaRiverOpossum
WhirlWind Propellers wrote:We have a new complete hub system available for the Razor X propeller blades.
:: The new Razor X[TRADE MARK SIGN] hub is highly engineered, with blade blocks made from strong and light billet aluminum.
-Patti
:proud:
Ms. Patti,
I hope you didn't mind me asking the price of the new hubs. I'm about to build a rotax 583 boat and will be shopping for a prop soon. What are your recommendations? I know several guys are already running these motors but I'm not sure what prop they're using
DynaMarine
Post by DynaMarine »
Awesome Patti! Love it!
Shane Lavalette
President/Owner
DynaMarine Performance Boats
785.218.9449
www.dyna-marine.com
shane@dyna-marine.com
Big Casino
Post by Big Casino »
Looking forward to my new 74" Excalibur - 4 blade "Bowtie" Hub from Patty. Bet it will look just as sharp !!!
"...This above all: to thine own self be true..."
Seven3
Post by Seven3 »
Anyone in the market for a new 6 cylinder AC prop is doing themselves a disservice if they're not considering the Razor X. Awesome prop across the board. I wouldn't trade mine for anything else available.
PeaRiverOpossum wrote:What is the price? I'll be calling soon.
Sorry, I guess I did forget to list the prices for the new 72" Razor X Hubs (diameters: 66", 68", 70", 72", 74" depending on blade length)
3-blade Razor X Hubs $350
5-blade Razor X Hubs $400
6-blade Razor X Hubs $425
Razor X blades $330/blade
*Available in Short (66"/68" L) or Standard (70"/72" L & R)
Complete Razor X direct-drive propellers (66", 68", 70", 72", 74")
3-blade Razor X Propeller $1340
5-blade Razor X Propeller $2,050
6-blade Razor X Propeller $2,405
Sincerely,
Patti
:proud:
Alvarez1112
Post by Alvarez1112 »
Any plans to build a 4 blade bowtie hub?
~Chris Alvarez
JW Customs LLC
Big Casino
Chris, They have one for the Excalibur Blade and it sure is a Bad Boy !!!!
Love mine
Alvarez1112
My turd won't swing four excalibur blades that's for sure!
~Chris Alvarez
JW Customs LLC
Alvarez1112 wrote:My turd won't swing four excalibur blades that's for sure!
What engine do you have? And what is your current propeller and diameter?
-Patti
:proud:
Bdriller
Post by Bdriller »
-Patti
:proud:
could you also make a razor recommendation for the 500 caddy direct drive thnx
B-White
Post by B-White »
-Patti
:proud:
I think the 4bld Excalbur bow tie would be the way to go..
Devil in the Bottle 83 ProMod
Marsh Master Step
Carbon Fiber Rudders by:HAMMERHEAD AVIATION.com
Prop is NOTHING BUT A WHIRLWIND!!!
RAZORX
Bdriller wrote: could you also make a razor recommendation for the 500 caddy direct drive thnx
For a direct drive Caddy, I'd first recommend the 4-blade Excalibur in 72" diameter ($2290). The Excalibur gives you all the same great light-weight instant thrust performance of the Razor X, but also gives you the low-end and mid-range performance of the wide-blade propeller styles.
The equivalent in the Razor X style is the 6-blade 72" diameter ($2405) for the direct-drive Caddy.
Sincerely,
-Patti
:proud:
Alvarez1112
-Patti
:proud:
Direct drive 4.3 v6 with a 68" 4 blade warpdrive. Standard cross hub
~Chris Alvarez
JW Customs LLC
-Patti
:proud:
So at 3000 RPM, the 4.3L V6 is probably putting out somewhere between 140 to 150 HP. My first choice would be to recommend the 3-blade 68" Excalibur ($1790) or if you wanted to upgrade only your current Warp Drive blades, the 68" Razor X blades, a set of 4 would be $1320 to run in your current hub.
Sincerely,
Patti
:proud:
Alvarez1112
Thanks! I'm working on some motor upgrades that will hopefully get me closer to 200 HP. Sure would be nice if these props could be spun up a few hundred more rpm's
~Chris Alvarez
JW Customs LLC
Bdriller
Post by Bdriller »
Sincerely,
-Patti
:proud:
Thnx
Dirtman
Post by Dirtman »
Patti are you guys going to be doing some like this hub for the larger props. You guys just got done refurbing 8 blades for me and although I haven't got to see the finished blades yet (really excited to see how they came out). One of those sweet looking hubs would sure look good on my new boat
chevy01
Post by chevy01 »
i have a stock 6.0 ls motor with a 2.12 rotator i am currently spinning a 74" 3 blade. max i can fit is a 76" do you have a 6 blade right hand rotation 76"
11'6 bigbad custom lycoming 0340 straight valve
Return to “Prop Talk”
