351w Prop?
Airboat propeller discussion.
MB608
351w Prop?
Post by MB608 »
I'm rebuilding a 12' laser with a 351w and 2.12:1 rotator gearbox, the engine is pretty new with forged pistons and RV cam running 350hp. The set up I have can fit a 74in prop. What prop do you guys think would be best for this boat?
plumcrazy
Re: 351w Prop?
Post by plumcrazy »
that pretty short for your set up i do have a prop that will work call me at Water Walker and we can talk about it
MB608
Re: 351w Prop?
Post by MB608 »
Since I'm limited to a max of 72-74" would it be better to run the saber/razor x blades instead of the wider blades?
mc1253
Re: 351w Prop?
Post by mc1253 »
What did you end up putting on for a prop?
351w pushing a 79" whisper tip ex , 2.68 ballistic on a 14' laser
1600 vw dd on a 12' sportcraft
the best time to fish is thru a hole in the ice
92-97 USMC
MB608
Re: 351w Prop?
Post by MB608 »
Im going with a 74in 3 blade falcon. Should have a ton of low end push.
Return to “Prop Talk”
