Lycoming o360 Angle Valve Prop?
Airboat propeller discussion.
GatorBoy77
Post by GatorBoy77 » Wed Apr 08, 2015 5:22 pm
I currently have a 70" whisper tip narrow on my o360 angle valve motor. I'm looking for more push.. Any suggestions on some props I need to look at? I was considering a 70" 5 blade warp drive or a 68" Ngq. Any advice would be much appreciated. Thanks!
10'6 Thurman
Lycoming AV O360
68" Sensenich NGQ
HomesteadGator
Re: Lycoming o360 Angle Valve Prop?
Post by HomesteadGator » Wed Apr 08, 2015 5:34 pm
I had the NGH on my old 12' full deck & ran dry no problem and it was nice and quiet. Boat ran in the low 70's. All around great prop.
FTD RACING
GatorBoy77
Post by GatorBoy77 » Wed Apr 08, 2015 5:43 pm
What size was the Ngh? I have been leaning towards the Ngq..wonder how they compare.
10'6 Thurman
Lycoming AV O360
68" Sensenich NGQ
HomesteadGator
Post by HomesteadGator » Wed Apr 08, 2015 5:59 pm
Short hub.. I think 68" might have been 70".. Can't remember
FTD RACING
hillbilly540
Post by hillbilly540 » Wed Apr 08, 2015 6:05 pm
68" NGQ hands down for push!!!...would be awesome on ur engine.
14'2" wide nose gilileo I0540 s/v , 74" sensenich NGQ
LSX1
Post by LSX1 » Wed Apr 08, 2015 6:13 pm
I have a AV0360 also with a 70''Q, pushes great on low end and cruise, not a good top end prop. Some say the NGQ performs great from low end to top end.A warp is not a good low end prop.My next prop will be a EXCALIBER 4 blade bow tie 70''. LSX1
Rich863
Post by Rich863 » Wed Apr 08, 2015 6:38 pm
68 cypress
:old_glory: :florida:
GatorBoy77
Post by GatorBoy77 » Wed Apr 08, 2015 7:52 pm
I may have to give the Ngq or Q a try. I have always had warp drives before, so not exactly sure what to expect.
10'6 Thurman
Lycoming AV O360
68" Sensenich NGQ
westsidE185
Post by westsidE185 » Wed Apr 08, 2015 8:25 pm
Warp drive I have one on my hunt boat has the snap to get you going on dry Plus u keep your speed. But you could ask 100 people what prop and they will all say something differnt. Honestly depends on the boat. not every boat will run the same with a prop. You can have to of the same boats and one may run better with one prop and one may run like shit with the same prop. Don't understand why but they do.
elChupacarburetor
Post by elChupacarburetor » Wed Apr 08, 2015 9:46 pm
The Sensenich Q or NGQ are pushier than an Italian housewife.
12' Gilileo / Lycoming O-360-A1A / 72" 3-blade Sensenich Saber
sseater
Post by sseater » Wed Apr 08, 2015 10:07 pm
had NGH and Q on my 200. I choose 70" Q hands down
GatorBoy77
Post by GatorBoy77 » Thu Apr 09, 2015 4:18 pm
I got the prop up for sale, so only a matter of time before I try a few out..
10'6 Thurman
Lycoming AV O360
68" Sensenich NGQ
Thunder200
Post by Thunder200 » Thu Apr 09, 2015 10:18 pm
I have 68 Cypress water walker. I've tried them all and to is my all around favorite. If your looking for push that's the ticket. I hear they will meet you at lake Kissimmee and let you try before you buy. Call them and check it out. PTR34 On here Terry deals with sense niche props and he will do the same thing.
Rich863
Post by Rich863 » Thu Apr 09, 2015 11:36 pm
Hey thunder200 what motor are you using to turn that 68" cypress
GatorBoy77
Post by GatorBoy77 » Fri Apr 10, 2015 4:46 pm
Thanks for all the info! There is definitely a lot of good options out there.
10'6 Thurman
Lycoming AV O360
68" Sensenich NGQ
GatorBoy77
Post by GatorBoy77 » Wed Apr 29, 2015 8:28 am
Ended up going with a 70" Cypress series from Water Walker. Pushes great and runs dry with two men. I have only tested it briefly but seems like its going to work well. Figured I would share and a big thanks to Andrew at Water Walker.
10'6 Thurman
Lycoming AV O360
68" Sensenich NGQ
Post by Deano » Wed Apr 29, 2015 8:34 am
Good deal. :thumbleft:
Rich863
Post by Rich863 » Wed Apr 29, 2015 9:54 am
What do you have it pitch at and how fast are you spinning it
GatorBoy77
Post by GatorBoy77 » Wed Apr 29, 2015 10:16 am
I have set at about the #2 mark at 2,850 Rpms on the trailer.
10'6 Thurman
Lycoming AV O360
68" Sensenich NGQ
Rich863
Post by Rich863 » Wed Apr 29, 2015 12:17 pm
I have a 68 I had it spinning 3000 on the water and it did ok put it at 2850 on the water and it's even better right on the 2 mark....does it pish better then your old Wisper tip
GatorBoy77
Post by GatorBoy77 » Wed Apr 29, 2015 1:25 pm
It definitely pushes better! I can't wait to try it out some more.
10'6 Thurman
Lycoming AV O360
68" Sensenich NGQ
Rich863
Post by Rich863 » Wed Apr 29, 2015 1:41 pm
Do you know how many degs you have in ot
GatorBoy77
Post by GatorBoy77 » Wed Apr 29, 2015 2:03 pm
I will have to put the digital level on it later.
10'6 Thurman
Lycoming AV O360
68" Sensenich NGQ
GatorBoy77
Post by GatorBoy77 » Thu Apr 30, 2015 6:27 pm
It's actually spinning up around 2800 rpms at 6.5 degrees. Should I take pitch out and spin it harder?
10'6 Thurman
Lycoming AV O360
68" Sensenich NGQ
Rich863
Post by Rich863 » Thu Apr 30, 2015 7:37 pm
2800 on the trailer? Mines at 8 deg but I'm not Shure if the motor was level 100% or not but the boat was on the ground not on trailer when I set it at 8 deg I'll check it with the motor level and see how many degs is actually in it....
Return to “Prop Talk”
