Which Prop
Airboat propeller discussion.
Cocoa 018
Which Prop
Post by Cocoa 018 » Tue Jun 02, 2015 10:09 pm
I'm new to the airboating world,I'm putting together a 13,3 big o hull,383 stroker with a Panther 2:1 rotator,which prop should I run,I will be doing mostly cruising no racing etc...
Whitebear
Re: Which Prop
Post by Whitebear » Tue Jun 02, 2015 11:11 pm
Moved this to Prop Talk instead of Airboat Talk.
Cocoa 018
Re: Which Prop
Post by Cocoa 018 » Tue Jun 02, 2015 11:27 pm
Thank you Whitebear
ptr34
Re: Which Prop
Post by ptr34 » Wed Jun 03, 2015 12:02 pm
2 blade R 80"
tons videos on YouTube ptr34
DannySauls
Re: Which Prop
Post by DannySauls » Wed Jun 03, 2015 8:02 pm
3 blade whisper tip 2.0 78" would be best option from whirlwind would be smooth and powerful, or if your looking for a 2 blade the 79" whisper tip EX would be a close second to the 3 blade. Feel free to pm or call if you have any questions
Danny Sauls
321-848-4719
mrbill
Re: Which Prop
Post by mrbill » Thu Jun 04, 2015 6:00 am
5 blade h by sensenich you will not beleave the snap push and speed with that 2.1 box i know some one running it on a much bigger boat and its insaine
GossB133
Re: Which Prop
Post by GossB133 » Thu Jun 04, 2015 7:49 am
I went from an 80" 2 blade H series to a 78" 3 blade Whispertip 2.0. The Whispertip pushes hard and my cruise is a lot better. The H series I believe is a good prop I just think I was turning it hard enough but I was afraid if I turned it harder my cruise would just go up too. Just my 2 cents but I have an 80" H series if you want to try it I'm looking to sell it.
16' Panther Aluminum hull with 3/8'' polymer, Stainless Steel Cage and rigging, single rear steer with a triple front, Full walk around deck, 377ci Chevy Stroker with a 2:1 Rotator Gearbox. 78" Whirlwind 3-Blade
air-roberts
Re: Which Prop
Post by air-roberts » Thu Jun 04, 2015 8:07 am
i'd prefer a 80 " whisper tip and if you like i can give you a great price on one just pm me if you like
Air-RobertsImage
New & Used PROPs
WhirlWind prop dealer
Return to “Prop Talk”
