NGQ
Airboat propeller discussion.
99blackdually
NGQ
Post by 99blackdually »
Has anyone tried a 66" or 68" ngq on a 200 lycoming? What are the results?
Griff
Re: NGQ
Post by Griff »
I'm running 72" NGQ on my 200 and pushes hard!
99blackdually
Re: NGQ
That's what I have been hearing about these props. I can not fit that big of one and I am surprised a 200 will spin one that big. What about cruise and top end?
Griff
Re: NGQ
Post by Griff »
Turnin it 2800 on about 1 and a half mark cruise is about 1,600 to stay on plane and fastest ever gps it was 54 mph with 2 people boat is HEAVY and I'm not lite either
rcr
Re: NGQ
Post by rcr »
Im building a 200 Angle Valve right now. I have been running a 180 and have a Water Walker Cypress Series Right now. My question is this, Are you running a 2 blade or a 3 blade NGQ? I am considering going with the 3 blade Short Bladed NGQ with it to try it out. Has anyone tried this blade setup on a 200 Angle Valve? And if so, how did it respond? Im trying to figure out whether to go with the 2 blade or the 3 blade. But I have about settled on the NGQ blades. The short blades are an inch thinner than the long blades.
Royce
1979 MAxCraft 14X5 Hull with Lycoming 0-360 200 HP / WaterWalker 70 Inch Cypress Series Prop
Rich863
Re: NGQ
Post by Rich863 »
How do you like that cypress tho
:old_glory: :florida:
Griff
Re: NGQ
Post by Griff »
2 blade
rcr
Re: NGQ
Post by rcr »
I love the cypress, It does great on the 180. However Im not sure whats going to happen when I finish the upgrade to the 200. That's why im asking about the different prop. I am currently running a 70 inch turning about 2700 RPMs on the trailer, about 2800 on the water.
Royce
signcoc43
Re: NGQ
Post by signcoc43 »
I'm running a 68 ngq and I love it. Thinking about going to a long hub to go 70 just to try it out
12 foot hamant fuel injected pe-90 520 conversion swinging a 68" ngq!!
" Yes my boat is slow!!!"
schmidtav2
Site Supporter - VII
Re: NGQ
Post by schmidtav2 »
I'm running the 68" NGQ on our Lycoming O-360 200hp boat, it works very well, good push low end and all around, not the fastest prop I've had on the boat, but the best pushing by far.
Griff
Re: NGQ
Post by Griff »
Hay Tom is the 68" u running on ya boat a 2 blade or 3?
Re: NGQ
Post by John Fenner »
Thinking on a 74-6 on an angle valve 540, thoughts?
schmidtav2
Re: NGQ
I'm running a 2 blade, tried the 3 blade in a 68" diameter but it was too much prop for the 200, I also tried the 3 blade 68" and a 3 blade 70" NGQ on our 540 boat, and I found that the 2 blade NGQ performs better on our 540 boat then the 3 blade version did, if you have the room swing a longer prop if possible the 74" & 76" dia out performed the 72" slightly on the ground
Re: NGQ
Ok, sounds about right, I advise no 3 blade props on O-540 anyway, seen fractured cranks from them. Will be in touch soon need an oil cooler.
Return to “Prop Talk”
