HELP. Prop hub adapter
Airboat propeller discussion.
struttnruttn
Post by struttnruttn »
I have a E225 Conv to 0470av It has the long splined crank I know I have seen a forum on here about a guy who builds these adapters but can't find it any one know who it is or anyone have one thanks :old_glory: :rebel: :florida:
Shippee123
Re: HELP. Prop hub adapter
Post by Shippee123 »
Not sure if his number but Bruce at Circle S made my spool adapter for my 0300a .
He's in Fort Mc Coy . Does great work !
bbstimey
Post by bbstimey »
there is not an adapter. you have a couple options though, you can have your prop hub drilled,or the spilned shaft cut off and the regular pattern hub welded on your crank.
14'x8' JB hull w/Stingered GO-480 w/ electronic ignition and 3 blade 80" R
struttnruttn
That's not the only options they have adapters that are made just looking for person that made them thanks
Crazy Frog
Post by Crazy Frog »
Maybe someone will chime in with Bruce's number...he does great machine work! He made an adapter for a oddball Franklin helicopter engine for me and did a great job. It might help if you add your location in the profile settings.
Shippee123
352-236-3580 was one I had.
BUSHHOG85
Post by BUSHHOG85 »
Without having the crank cut the only adapter you can run is the factory aircraft style splined hub. It can be machined down and drilled to the 6 bolt pattern but you will have to have a 3 inch hole bored through your prop hub.
SC 480 13x7'6 HAMANT
520 13' RICOCHET
swampdragon
Post by swampdragon »
That is Bruces number but he has been Verginia this week. He can fix you up.
barhopper
Post by barhopper »
Is that the guy out by Gores Landing on the river road?
swampdragon
Yes and he is back.
krazymatt
Post by krazymatt »
Msg Packman on here back when I was lookin for one he had 1 or 2 of them.
bbstimey
Post by bbstimey »
i would sure like to see one of these adapters
krazymatt
Post by krazymatt »
bbstimey wrote:i would sure like to see one of these adapters
Prop adapter
Prop adapter
Backside of adapter.
My motor without adapter on it. O-435
krazymatt
Post by krazymatt »
Prop adapter on crankshaft.
Lycoming factory flywheel installed, center was bored out to 3" to clear the center hub of prop adapter.
With warp drive hub installed. Warp drive plates center bore was opened up to 3" also to clear the prop adapter hub. The prop adapter is held on by the factory but threaded onto the end of the crank shaft.
bbstimey
Post by bbstimey »
that's not an adapter, that's the way the come
bbstimey
Post by bbstimey »
i have a few of those
krazymatt
Post by krazymatt »
bbstimey wrote:i have a few of those
Maybe you can help the man out then.
bbstimey
Post by bbstimey »
pm'ed me never responded back
Return to “Prop Talk”
