0470 what prop?
Airboat propeller discussion.
Blowboatin_
0470 what prop?
Post by Blowboatin_ » Mon Sep 07, 2015 7:39 pm
0470 sitting on a 11' sled can only swing up to a 70" blade. Thinking about a 70" power shift or 70" NGQ.
Suggestions please!!!
jeepinocala1111
Re: 0470 what prop?
Post by jeepinocala1111 » Mon Sep 07, 2015 9:36 pm
Haven't had a chance to ride mine yet but went with a ngq all I can say so far is it's built real nice one of the best looking props I've seen. Go quiet and we can stop the regulations.
GeeLeDouche
Re: 0470 what prop?
Post by GeeLeDouche » Thu Sep 10, 2015 12:42 pm
I think a 70 inch NGQ would push like crazy low end. I would also good look at a whirlwind whispertip if I were you.
What is the purpose of your boat? Do you wanna drive dry ground or go crazy fast? Maybe look into a set of Sabers / Razors if your into the go fast boats..??
flcracker9
Re: 0470 what prop?
Post by flcracker9 » Thu Sep 10, 2015 3:15 pm
I had a 3 blade H on mine, ran pretty good. I have a new 72" NGQ, haven't had a chance to test it yet, hoping to get a little better low end push. I don't think you can go wrong with the NGQ
Blowboatin_
Re: 0470 what prop?
Post by Blowboatin_ » Thu Sep 10, 2015 7:12 pm
I currently have a 68' whirlwind on it and I don't like it, I mean it works but i can just feel there should be way more push with that motor.
Also I like having a boat that can do well over 50 but having that low end push to get me where I want to go is most important to me
ptr34
Re: 0470 what prop?
Post by ptr34 » Thu Sep 10, 2015 10:49 pm
68 ngq
tons videos on YouTube ptr34
jrlyles
Re: 0470 what prop?
Post by jrlyles » Tue Sep 15, 2015 4:28 pm
I ran a 72 Q.on a 12 ft palm beach hull that did real good.
Junior Lyles
Volusia County Sportman's Conservation Association
Florida Airboat Association Member
Preach & lead singing at revival meetings on the side
Southern Style
Re: 0470 what prop?
Post by Southern Style » Mon Sep 21, 2015 5:27 pm
72" Whisper Tip is what I am running....
KRVSA Member
SJRAA Member
KCCO
Return to “Prop Talk”
