Prop Torque Setting
Airboat propeller discussion.
Everglades_Rebel
Prop Torque Setting
Post by Everglades_Rebel »
Out in 3A yesterday it felt like one of the blades on my 3 blade 80 inch Sensetech props was loose. Any idea of what the Torque should be set to?
:rebel: 2013 14x8 Diamondback Ultra Lite Hull, 400HP hopped up SBC, 2.38 Stinger Gear Box, 3 blade Sensenich 80' inch prop :rebel:
"Any society that would give up a little liberty to gain a little security, will deserve neither and lose both"
Re: Prop Torque Setting
Post by John Fenner »
65 foot pounds.
RickMc
Post by RickMc »
What should a 4 blade warp drive torqued to ? Both the small blocks that hold the blades and the 6 big ones that hold it on .
The glass is always half full....til I get a hold of it
If the hub is LXL with 1/2" bolts 65 foot pounds, the blade clamps are 5/16" and shall be 9 foot lbs and or 108 inch pounds.
Return to “Prop Talk”
